11 members (FAST55, panel fan, Wayne67vert, Gdads51, Lightholder's Dad, gswbbc, 48jim1ton, frogfarmer, tclederman, Ponchogl, 1 invisible), 106 guests, and 0 robots.
Topics128,049
Posts1,055,553
Members48,425
#1018340 03/31/2014 2:17 AM
at swap meet today seen Ad with bed liner on running boards , I liked it . any thoughts ?? Any of you every done this ?I think its roll on .
" STUCK IN THE '50'S "
Its been done. Individual taste rules I suppose. I think it would depend on how bad the running boards are to repair bad places...otherwise I like the paint.
The Boards aren't bad , I just liked the look , and the safety of the no slip . I've already painted the cab satin black so it should match .
I did mine as well, for the reasons that wanderer1955 1rst mentions. I also used it on the cab floor, it helped to provide a little bit of sound deadening. It's not hard to work with, I used the Duplicolor brand which also comes in a spray version.
Bill Burmeister
Make sure all the primer/paint in on the bed sheet-metal/wood is well adhered to the metal.
Otherwise, liner will cause separation after a while.
My truck is "repaired" not "restored" so I used it on the running boards to make the dents and dings less visible. Also does not show scratches from stepping on it like shiny paint does, but does easily show dirt. I think it makes the truck look more utilitarian.
Harold Wilson
41 Chevy 3/4 Ton
back yard wrench turner
W Online: Content
I used it on my running boards and under the cab for sound deadening.
I don't want to worry about scratches on the running board like fellow bolter LonnieC. smile
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
My boards were rotted thru so I replaced the deck and had them done with Line X which has held up as claimed for several years. IMO the only way to go is with a product that is sprayed on hot and has a lifetime guarantee. I went back the next spring and had all 4 fenders done for $100 each and would do it again without hesitation for the noise differential alone.
You Tube
