| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | at swap meet today seen Ad with bed liner on running boards , I liked it . any thoughts ?? Any of you every done this ?I think its roll on .
" STUCK IN THE '50'S "
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Its been done. Individual taste rules I suppose. I think it would depend on how bad the running boards are to repair bad places...otherwise I like the paint. | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | The Boards aren't bad , I just liked the look , and the safety of the no slip . I've already painted the cab satin black so it should match .
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I did mine as well, for the reasons that wanderer1955 1rst mentions. I also used it on the cab floor, it helped to provide a little bit of sound deadening. It's not hard to work with, I used the Duplicolor brand which also comes in a spray version.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Make sure all the primer/paint in on the bed sheet-metal/wood is well adhered to the metal.
Otherwise, liner will cause separation after a while.
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | My truck is "repaired" not "restored" so I used it on the running boards to make the dents and dings less visible. Also does not show scratches from stepping on it like shiny paint does, but does easily show dirt. I think it makes the truck look more utilitarian.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Sep 2010 Posts: 1,700 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,700 | I used it on my running boards and under the cab for sound deadening. I don't want to worry about scratches on the running board like fellow bolter LonnieC.  Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | My boards were rotted thru so I replaced the deck and had them done with Line X which has held up as claimed for several years. IMO the only way to go is with a product that is sprayed on hot and has a lifetime guarantee. I went back the next spring and had all 4 fenders done for $100 each and would do it again without hesitation for the noise differential alone.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
