| | | Forums66 Topics128,074 Posts1,055,999 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 24 | an anyone provide me with good pictures of door seal installation? I bought the rubber, and the windlace is one better than the other? Do you use both? Does it go underneath the trim retainer?
thanks | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I know 41-46 only had wind lace. The seal they sell for the 41-46 would never allow my doors to close. I used the one shown in my photo bucket and can get the doors closed. It has been two weeks and I tried to tighten the latch a little today but the rubber has not compressed enough to make it tighter. | | | | | Joined: Sep 2013 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 24 | Thanks for the reply I looked at your photos. Pretty nice job on the truck! I didn't see the wind lace pic? Does it go underneath the Trim pieces that go around the cab? | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Yes it goes around the inside under the trim that's about 3/4 inch wide. I think that was the only seal back then. The bad part is that it allows water all the way to the wind lace. On the 41-46 water gets to the edge of the dash and runs under some trim pieces that hide the hinge screws. I think the outside seal is great if you can find one that will fit. Mines not on the road yet so how well my seal works I don't know yet. | | | | | Joined: Sep 2013 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 24 | Thanks a lot! I am going to give it a try tomorrow. I let you know how it goes.
| | | | | Joined: Sep 2013 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 24 | Ok got it installed closed up the air gap definitely not water tight
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | That's great. Good luck finding a outer seal | | |
