1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1018045 03/29/2014 9:18 PM
an anyone provide me with good pictures of door seal installation? I bought the rubber, and the windlace is one better than the other? Do you use both? Does it go underneath the trim retainer?
thanks
1940 Chevrolet 1/2-Ton
More pix and video on Photobucket
Clyde's/Dad's 1953 Chevy 1/2-Ton
I know 41-46 only had wind lace. The seal they sell for the 41-46 would never allow my doors to close. I used the one shown in my photo bucket and can get the doors closed. It has been two weeks and I tried to tighten the latch a little today but the rubber has not compressed enough to make it tighter.
Thanks for the reply I looked at your photos. Pretty nice job on the truck! I didn't see the wind lace pic? Does it go underneath the Trim pieces that go around the cab?
Yes it goes around the inside under the trim that's about 3/4 inch wide. I think that was the only seal back then. The bad part is that it allows water all the way to the wind lace. On the 41-46 water gets to the edge of the dash and runs under some trim pieces that hide the hinge screws. I think the outside seal is great if you can find one that will fit. Mines not on the road yet so how well my seal works I don't know yet.
Thanks a lot! I am going to give it a try tomorrow. I let you know how it goes.
Ok got it installed closed up the air gap definitely not water tight
That's great. Good luck finding a outer seal
Moderated by  ndkid275, Phak1
