1 members (baldeagle),
32
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2013 Posts: 73 | OK I got the old 61 GMC half ton done enough to drive some. well in sort of a loose way any way. the old 305 VK runs pretty good as far as I can tell so far. got the speedometer working, and it checks real close by a GPS. I have a glass pack muffler under there with not much tailpipe like I got it. some rubber seal gone under the doors as well as no floor mat. so plenty of noise on the road. anyway I have 215/85 R16 tires and 4.11 gear so must be close to factory tire size since the spedo is so close. with all the noise in the cab it's hard to know how much the engine is winding but it feels like it likes to run between 60 and 65. I would guess the old engine can handle a little more speed but don't want to strain it either. doesn't smoke or knock and I think I got the after market holley 2 bbl. set up about right. plugs points and timing good. I know I can't run it the legal Texas 75 but kinda wondering if anybody running one similar thinks it would handle a little more without straining it? eventually I'll get the floor mat in, door seals on and a few other quiet down items to make it more enjoyable. right now I just want to use it some without feeling like the turtle in the road. Raymond | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I have no experience with the V6 so I can't help you there but I want to say I like your truck.
I do know the earlier GMC straight sixes were famous for running loaded, wide open, all day long. I'd bet the V6s were run the same way.
The 3.07 gears would be a big improvement but I'd recommend an OD transmission. I run an SM319 behind the 248 in the Suburban. I can run 70-75 all day long with the engine purring, not roaring.
I'd also recommend power front discs if you are going to be running 70-75. | | |
