7 members (klhansen, frogfarmer, Gdads51, Hotrod Lincoln, 1955 1 Series, Goach2, 1 invisible), 106 guests, and 3 robots.
Topics128,198
Posts1,057,269
Members48,466
I'm doing a small block swap in my 49 3100 and I was wondering if anyone had any pics on how they modified the firewall for the bell housing and how they made the tunnel for the trans
headscratch
I've seen a lot done without modifying the firewall or floor. Are you doing any other mods or just this?
My 46 GMC on Photobucket
Just did one on a 55 frist and did not have to do anything to the fire wall or the floor.Put in a SBC and a 700 4r trans.
Pete
I agree….
Like 46GMCpu …..
I have a 455 Buick and a turbo 400 in my 51 panel and zero firewall or tunnel issues.
A small block should have loads of room without any firewall mods.
....52 panel. Installed a small block Chevy. Did not modify firewall. Used a BIG distributor and can still get my hand between the dist. and firewall.
I set my engine in using this layout.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Engmount.jpg
EDIT: I did trim about 1/2" off at the front of the transmission hole where the tranny came against it when leveling the engine...but just a little.
If I remember correctly, my '49 had the engine set so far back that a bump had to be put in to the firewall for a valve cover. Amongst other things. On my Suburban, everything tucked in nicely without modifying any sheet metal.
