| | | Forums66 Topics128,181 Posts1,057,185 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 37 New Guy | | New Guy Joined: Mar 2012 Posts: 37 | I'm doing a small block swap in my 49 3100 and I was wondering if anyone had any pics on how they modified the firewall for the bell housing and how they made the tunnel for the trans | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 |  I've seen a lot done without modifying the firewall or floor. Are you doing any other mods or just this? | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Just did one on a 55 frist and did not have to do anything to the fire wall or the floor.Put in a SBC and a 700 4r trans.
Pete | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | I agree….
Like 46GMCpu ….. I have a 455 Buick and a turbo 400 in my 51 panel and zero firewall or tunnel issues. A small block should have loads of room without any firewall mods.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....52 panel. Installed a small block Chevy. Did not modify firewall. Used a BIG distributor and can still get my hand between the dist. and firewall. I set my engine in using this layout. http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Engmount.jpgEDIT: I did trim about 1/2" off at the front of the transmission hole where the tranny came against it when leveling the engine...but just a little.
| | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | If I remember correctly, my '49 had the engine set so far back that a bump had to be put in to the firewall for a valve cover. Amongst other things. On my Suburban, everything tucked in nicely without modifying any sheet metal. | | |
