6 members (rfs56trk, TrknGMC, Gray_Ghost, Wally / Montana, walter74, 1 invisible), 75 guests, and 4 robots.
Topics128,056
Posts1,055,803
#1014856 03/17/2014 12:57 PM
Hi,
The factory Harrison radiator on my 1951 3/4 ton is leaking.
I had a friend that had an extra 1952 1/2 ton radiator which I attempted to install.
The radiator from the 1/2 ton is about an inch less in thickness, and appears to be not tall enough.
I am guessing that the radiators between 1/2 and 3/4 ton are different, or is this due to the year?
Anyway, does anyone make an aftermarket 3/4 ton radiator that will fit as a "bolt in"?
Keith
1951 3600 Chevrolet
norrisk66 #1014897 03/17/2014 3:55 PM
Why not take your rad to a local rad shop? If you have a good shop they should be able to clean it and fix it pretty cheap.
My 46 GMC on Photobucket
norrisk66 #1014915 03/17/2014 5:09 PM
If they cannot fix it and you have to get another one I sourced mine from ClassicParts.com. I just got the standard duty they offer and it fit perfect and has performed well in almost three years of service.
norrisk66 #1014960 03/17/2014 8:19 PM
This radiator looks like it was previously repaired by
"Sir-hacks-a-lot" himself and is in pretty bad shape. I am sure they could re-core it, but I imagine it will be pricey.
Has anyone had any luck with the aluminum aftermarket radiators? My main concern is keeping truck looking somewhat stock.
1951 3600 Chevrolet
norrisk66 #1014979 03/17/2014 10:23 PM
I had the original radiator re-cored in my '62 Bel Air for less than $300. If you want to keep it looking stock that's your best bet.
norrisk66 #1014990 03/17/2014 11:09 PM
If you were in Illinois, I'd sell you an origianl 3/4 ton radiator.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
norrisk66 #1015022 03/18/2014 1:21 AM
"The Fake Truck"
norrisk66 #1015025 03/18/2014 1:26 AM
1949 Beast
1949 Beast
I got one from my local radiator shop. $500
