Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Rusted Nut, sron48, TIM ZINDLER, baldeagle, 3B), 30 guests, and 2 robots.
Topics128,005
Posts1,055,253
Members48,418
#101408 06/30/2007 10:05 PM
Hi all,
A few weeks ago I started having intermittent starter problems. The truck would start fine 9 times, then not start for a day, then turn over fine the next day. I'd turn the ignition and not even get a click. I had my battery checked and it read 15.5 volts. The battery was OK, but I was told my voltage regulator was bad, and that I needed a new starter. I put in a new voltage regulator and the truck started great, repeatedly, for a week. I figured I didn't need the starter, so I returned it. An hour later, same problem. Yeah, pretty funny, I know. Do you think it's the starter? The battery tests good now with the new regulator. Any tips are appreciated.
#101409 06/30/2007 10:23 PM
olchevynut,
WOW...15.5 volts. That's pretty high! With the charging system going full bore, most electrical guru's say that 14.8 is absolute max.
If you have a solenoid starter, next time the starter does its thing, hook a voltage tester to the 'S' terminal and see if the solenoid is seeing voltage when the key is turned to START. I think one of two things are happening. The key switch might be old and funky and isn't switching power to the solenoid when turned to START, or the solenoid itself is marginal and isn't pulling in when the key tells it to.
Chevrolet's are famous for this problem. Some folks carry a sawed off broom handle with them and when the solenoid refuses to pull in, they pop the hood and tap the solenoid as their buddy turns the key on.
When the solenoid slams closed, it closes a large copper contact and signals the starter to turn. If it doesn't close, the starter won't spin. The telltale 'clicking solenoid' is another audible clue. You might have someone verify the actual output of your charging system again....when you get into the 15 volt range, your battery is going to boil and its life will be shortened.
Stuart
#101410 07/01/2007 5:52 AM
olchevynut,
I looked at some of your previous posts. It looks like your '65 could have a automatic transmission. This would mean it has a neutral starter safety switch that could prevent the starter from engaging if it weren't working or adjusted properly. Just a thought!
Stuart
#101411 07/01/2007 3:11 PM
Riding in the Passing Lane
Those starters are easy to work on yourself. If you take it apart & clean it up, put new brushes in if needed, it will usually fix it. You can take the back off the selinoid & clean up the contacts. If the post inside is gooved you can loosen it up & turn it around using the good side. Make shure you get the nut that holds the S term in tight so it makes good contact inside.
1972 Chevy c10 Cheyenne Super
#101412 07/01/2007 6:04 PM
Thanks guys,
Gonna take it out today and look. I'm somewhat mechanically challenged so we'll see. Atomarc, you're right. It is an automatic. It's got a 350 with a 350th. The guy at Standard Battery was pretty surprised with the high reading too so he took off the surface charge and checked the battery again. I figured if he told me the battery was still good and wasn't trying to sell me a new one, he was probably being straight with me. A mechanic buddy I know did the solenoid tap too, and it worked so that's probably the route to go. Thanks again guys.
