2 members (Otto Skorzeny, Bill Hanlon), 37 guests, and 3 robots.
Topics128,035
Posts1,055,445
Members48,422
#1012256 03/07/2014 1:18 AM
I have a 292 engine that I am trying to determine the year, the numbers I find on the block are C4J169377, also there is a
FO620THU. these numbers do not appear on any casting chart that I have seen. Any help in decoding this?
Welcome aboard.
You can find the casting numbers on inliners.org
Your casting number appears incorrect, it should be 6-7 digits. The number is found on passenger side about middile under side covers.
FO620THU, is I believe the engine code from the distributor pad.
I've had a hard time finding engine codes for a six cylinder.
Larry
I don't own a vehicle that isn't old enough to drink.
Thanks for the info = dp
1 Offline
Also, all GM, Ford and Chrysler/Dodge engines have a casting date code on all their blocks and heads,its usually a 4 digit number,for instance, K 22 4. K being the month, 22 being the day, and 4 being the year.
We cannot solve our problems today using the same thinking we used when we created them!
Albert Einstein
Check date codes on attaching pieces as well. Intake should have one along with the head. Look for the big GM cast on the side of the block, then move back a few inches to find the date code.
Joe
