2 members (Hotrod Lincoln, TexasA&M48Truck), 186 guests, and 1 robot.
Topics128,082
Posts1,055,964
Members48,430
#1012331 03/07/2014 4:29 AM
Nice truck for $500...I don't think you hurt yourself with that purchase.
Not sure I understand your question???
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
500 is great for a truck in that shape
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
V
V Offline
Nice lookin truck! I dont think you payed a half bad price for that. With a little elbow grease and some wrenches I'll bet you'll have her runnin like a swiss watch.
1948 Federal 25M
More pix on Photobucket
1947 Farmall M
This story is also on the Gallery page
Nice truck! It looks like a complete,un-molested truck! you did fine! I'm jealous!
Mo' Tater
It looks good. This is just another example that old farm trucks just don't fetch much money. However $500 is a bargain. It looks more like a $1000 to $1500 truck to me.
Moderator
Moderator
2 Offline
Great looking truck rgunnz!
I have never paid over 500 for and old bolt except for a 67 9500 GMC.
15 years ago, there were a couple that I bought at auctions for under 100. Then got what parts I needed and gave them away.
No titles of course.
And there are more stories.
Since you are in Kansas, you should try to join us at KC in September. you will meet some great people and have a good time.
2-Ton
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
I think maybe your question is where should I start to get this on the road?
-Make sure the engine turns.
-Fuel system
-Brake system
-Pour coolant in and see if any comes out due to cracks in the block
-wiring harness
-Change fluids
The list is long, but if you make a detailed list and start crossing things off, it will be road worthy in very little time!
Nice find and a very good price. You probably paid just a few dollars over scrap value for that.
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
2-Ton #1012487 03/07/2014 8:13 PM
Thanks. I will definitely look into it.
RDomeck, Thanks for the reply and advice. The motor is free. The truck has not ran since 87 from what the seller told me. The only problem I have so far is with the brakes! The pedal is frozen in the up position. So don't know what is could be. Again thank you everyone. I will update.
Sounds like your M.C. piston corroded and stuck. You might be better off replacing it,than re-sleeving the old one. If the M.C. is that bad,I'd replace the hydrovac,as well. Don't forget to replace the rubber brake lines. They deteriorate from the inside,restricting flow/pressure. Steel lines rust from the inside,too. Wheel cylinders are available through N.A.P.A.,as well as other F.L.A.P.S. With the money you saved on the payment,you can buy a complete new brake system,and still be in the $1500.00 price range! Not bad!!
Mo' Tater
