| | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 48 | | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Nice truck for $500...I don't think you hurt yourself with that purchase. Not sure I understand your question??? Mike B  | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | 500 is great for a truck in that shape
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Jan 2014 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2014 Posts: 30 | Nice lookin truck! I dont think you payed a half bad price for that. With a little elbow grease and some wrenches I'll bet you'll have her runnin like a swiss watch. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Nice truck! It looks like a complete,un-molested truck! you did fine! I'm jealous! | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | It looks good. This is just another example that old farm trucks just don't fetch much money. However $500 is a bargain. It looks more like a $1000 to $1500 truck to me. | | | | | Joined: Aug 2001 Posts: 3,596 Moderator | | Moderator Joined: Aug 2001 Posts: 3,596 | Great looking truck rgunnz! I have never paid over 500 for and old bolt except for a 67 9500 GMC. 15 years ago, there were a couple that I bought at auctions for under 100. Then got what parts I needed and gave them away. No titles of course.
And there are more stories.
Since you are in Kansas, you should try to join us at KC in September. you will meet some great people and have a good time.
2-Ton 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | I think maybe your question is where should I start to get this on the road?
-Make sure the engine turns. -Fuel system -Brake system -Pour coolant in and see if any comes out due to cracks in the block -wiring harness -Change fluids -......
The list is long, but if you make a detailed list and start crossing things off, it will be road worthy in very little time!
Nice find and a very good price. You probably paid just a few dollars over scrap value for that. | | | | | Joined: Apr 2013 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 48 | Thanks. I will definitely look into it. | | | | | Joined: Apr 2013 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 48 | RDomeck, Thanks for the reply and advice. The motor is free. The truck has not ran since 87 from what the seller told me. The only problem I have so far is with the brakes! The pedal is frozen in the up position. So don't know what is could be. Again thank you everyone. I will update. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Sounds like your M.C. piston corroded and stuck. You might be better off replacing it,than re-sleeving the old one. If the M.C. is that bad,I'd replace the hydrovac,as well. Don't forget to replace the rubber brake lines. They deteriorate from the inside,restricting flow/pressure. Steel lines rust from the inside,too. Wheel cylinders are available through N.A.P.A.,as well as other F.L.A.P.S. With the money you saved on the payment,you can buy a complete new brake system,and still be in the $1500.00 price range! Not bad!! | | |
