1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | read with interest the post of oil on fuel pump. my 1952 with the original 216 is making oil. it has the fuel pump with the built-in filter and I am suspecting the pump to be the source of the increasing oil level. does anyone have any thoughts? | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Does your oil smell like fuel? | | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | it does have a faint fuel smell to it. the oil needs changing and more of a used oil smell. level about an inch above full and I have not added any in the past several months. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Better get a new fuel pump and change that oil.
| | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | thanks, exactly my thoughts, question is; can fuel pumps with built in filter still available. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes and you have a leaky diaphragm. Very dangerous having fuel vapor in the crankcase. Way back in the mid 60's my 235 in my '60 Biscayne sprung a leak crossing the desert on my way to my next duty station. It blew over to the exhaust and caught fire. I manage to put it out with some rags but not before it had burned up the ignition wires. After some time someone finally came by (back then there wasn't much traffic crossing the desert) and gave me a ride into town.
We towed it back and I spent the night waiting to get the repairs done and get back on the road. I was lucky the whole car didn't go up in flames. Leaky fuel system is nothing to play with.
Denny G
Denny G Sandwich, IL
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Its either fuel or coolant. If the oil is a coffee with cream light brown (not the carbon black) its coolant. Fuel will not change the color of oil much. What your dipstick with coolant in the oil will look like If you have leaked enough fuel into the pan to rais the level it will smell like gas.. no doubt about it. So check your coolant level also.
