1 members (baldeagle), 94 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#1012318 03/07/2014 3:58 AM
read with interest the post of oil on fuel pump. my 1952 with the original 216 is making oil. it has the fuel pump with the built-in filter and I am suspecting the pump to be the source of the increasing oil level. does anyone have any thoughts?
1952 Chevy Pickup Truck
papas52 #1012323 03/07/2014 4:10 AM
Does your oil smell like fuel?
alltruck72 #1012326 03/07/2014 4:15 AM
it does have a faint fuel smell to it. the oil needs changing and more of a used oil smell. level about an inch above full and I have not added any in the past several months.
papas52 #1012329 03/07/2014 4:21 AM
Better get a new fuel pump and change that oil.
Roy Rodgers #1012330 03/07/2014 4:28 AM
thanks, exactly my thoughts, question is; can fuel pumps with built in filter still available.
papas52 #1012410 03/07/2014 2:47 PM
Yes and you have a leaky diaphragm. Very dangerous having fuel
vapor in the crankcase.
Way back in the mid 60's my 235 in my '60 Biscayne sprung a leak
crossing the desert on my way to my next duty station. It blew
over to the exhaust and caught fire. I manage to put it out
with some rags but not before it had burned up the ignition
wires.
After some time someone finally came by (back then there wasn't
much traffic crossing the desert) and gave me a ride into town.
We towed it back and I spent the night waiting to get the
repairs done and get back on the road. I was lucky the whole
car didn't go up in flames.
Leaky fuel system is nothing to play with.
Denny G
Denny G
Sandwich, IL
papas52 #1012648 03/08/2014 11:43 AM
Its either fuel or coolant. If the oil is a coffee with cream light brown (not the carbon black) its coolant. Fuel will not change the color of oil much.
What your dipstick with coolant in the oil will look like
If you have leaked enough fuel into the pan to rais the level it will smell like gas.. no doubt about it.
So check your coolant level also.
