1 members (baldeagle),
107
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 5 New Guy | | New Guy Joined: Mar 2014 Posts: 5 | I have a 292 engine that I am trying to determine the year, the numbers I find on the block are C4J169377, also there is a FO620THU. these numbers do not appear on any casting chart that I have seen. Any help in decoding this? | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Welcome aboard.
You can find the casting numbers on inliners.org
Your casting number appears incorrect, it should be 6-7 digits. The number is found on passenger side about middile under side covers.
FO620THU, is I believe the engine code from the distributor pad.
I've had a hard time finding engine codes for a six cylinder.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Mar 2014 Posts: 5 New Guy | | New Guy Joined: Mar 2014 Posts: 5 | | | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | Also, all GM, Ford and Chrysler/Dodge engines have a casting date code on all their blocks and heads,its usually a 4 digit number,for instance, K 22 4. K being the month, 22 being the day, and 4 being the year.
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
| | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | Check date codes on attaching pieces as well. Intake should have one along with the head. Look for the big GM cast on the side of the block, then move back a few inches to find the date code.
Joe | | |
