5 members (Barry Martak, J Lucas, rfs56trk, Otto Skorzeny, 1 invisible), 86 guests, and 2 robots.
Topics128,094
Posts1,056,487
Members48,444
First post and I need some advice. I am hoping to pick up a 65? (I'm not positive on the year) C10 that has 45k original miles in the next few weeks. It has been sitting in a truck shed for 24 years since my wife's great-grandparents passed away. What do y'all suggest as the first things to do? I'm thinking hoses, belts, spark plugs, battery, replace engine fluids, check wiring, empty gas tank and check for rust, overhaul brakes, new tires. What am I missing? My intentions for this truck is a driver, get it running and drive it for a while then think about cosmetic stuff as it is a little rusty. I'm in MS and for most of the time the truck was covered pretty well but after some good wind the last few years the truck shed became unstable and roof was about half gone so the shed has been torn down. Now I'm in the process of talking my wife's grandfather into giving me the truck instead of another family member. Thanks for the input.
I'd probably follow what you suggest. The main thing is running and stopping, so handle that first. Good luck with it and if possible post pics. Barn finds, especially family barn finds are the best. Lucky you!
Drew
These are some pictures of the truck in the shed before the shed was torn down. http://www.flickr.com/photos/119388871@N02/12930175185/
Planning on leaving this in the back window. http://www.flickr.com/photos/119388871@N02/12930258063/
The interior is in good shape as far as i can tell. http://www.flickr.com/photos/119388871@N02/12930256903/
http://www.flickr.com/photos/119388871@N02/12930248463/
Looks like a real survivor thumbs_up
Trying to prevent damage to the cylinders - rings - pistons - valves, due to rust, and getting rust from the fuel system into the carb / engine would also be a concern since it has been sitting that long, in a humid climate.
Here is an excellent step by step procedure for starting up an engine that has been sitting for a long time: http://www.kaiserbill.com/Web-PDF/Start-Up.pdf
That looks to be one nice truck! Follow John's advice and take your time and you'll have a jewel!
Best wishes,
Les
