4 members (Wayne67vert, delky, Peggy M, 1 invisible), 83 guests, and 2 robots.
Topics128,060
Posts1,055,839
Members48,427
#101127 06/11/2007 9:40 PM
Just a note. The guy who inspects my '49 each year has always complained about not being able to see rear tail light brake and parking lights light up in the sun. Got some halogen 1157 bulbs from JC Whitney and installed them, Much brighter and he's happier. In case someone has the same problem.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
#101128 06/12/2007 3:29 PM
Just a note of caution...those puppies run HOT. If you have plastic lens, they will/can melt. If you have glass lens, those bulbs will heat up the glass and when rain hits them they may crack. Have seen both of these problems occur on streetrods.
#101129 06/12/2007 5:22 PM
Would a 1157 style led bulb be just as bright and run cooler? I'm thinking about them for the back of my '53, which as geezer says, the stock ones just aren't very bright.
#101130 06/12/2007 6:23 PM
Ex Hall Monitor
Ex Hall Monitor
There are few choices of 6V LEDs but they are available. Be aware that most are directional and from what I've seen personally the number of LEDs makes a difference. (more LEDs = more light) I use these and I'm quite pleased with them. They light the whole taillight & have substantially more LEDs than the other bulbs I've seen. You can get cheaper bulbs but the ones I've seen have fewer LEDs and are directional so they provide a "hot" red spot in the middle of the lens instead of lighting the whole taillight. 4ontheFloor was working on a project for making 6V LEDs but I'm not sure of the status.
#101131 06/13/2007 9:58 PM
I'm using led's and they take a whole lot less juice and are a bunch brighter
#101132 06/14/2007 2:52 AM
I tried the halogens, they were a little brighter, and worked ok. Until they burn out anyways. Seems to me that the life is a little short for my tastes. I also tried the led bulbs. They would be fine for a lens not equipped with blue dots. The have to have the same color lens as the lamp illumination to work properly. The blue dots end up lining up with the lamp, and therby actually block some of the light. I ended up going with a Technostalgia conversion kit. It uses a panel of leds instead of a bulb. I further modified it to allow for a blue led behind the blue dot, so it has it's own lamp for illumination.
There's also complete assemlies and replacement lenses that have leds built in, about 30 or so per housing. They look pretty good, too.
Bill Burmeister
#101133 06/14/2007 1:38 PM
I used the replacements with about 30 leds(39Ford tailights)
