4 members (Donf, FAST55, Shaffer's1950, greenie-reddy), 34 guests, and 3 robots.
Topics128,154
Posts1,056,838
Members48,456
#931847 03/31/2013 10:13 AM
We ordered a 8 lug (6 1/2 on 8) 16x7 lug steel wheel from Wheel Vintiques to see if it would fit on the old 3/4 ton. I think we're good to go! We're hoping to mount up a 235/85r16 later today and test that fit too.
Here are some pics in case anyone is curious:
Wheel
Mounted
Tie Rod Clearance
Tie Rod Clearance
Looking good. We have about the same set up. I have a 1950 3600. I used trailer wheels (16 inch, 8 lug) from Dexstar made in USA. Powder coated and 3 inch offset so fit great. I used the same size tires as you (cooper, made in USA)
You should find some pics of my set up in my album (under my sig below...)
I'm just starting on body and paint now.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Impressive progress on your bolt, thanks for sharing.
We're in the process of getting it safely down the road and fixing what needs fixing.
Do you have a picture of the truck with the wheels on it now?
Still working on the full set. We'll post up some pictures in a month or 2.
We finally got all 4 wheels and mounted the radial tires. Unfortunately, the Wheel Vintique chrome half moon hub caps don't fit, the front and rear hubs stick out to far. We'll have to figure out what to do for caps. The tires are pretty tall as well. We have slight rubbing on the left side.
Tires are: BF Goodrich All Terrain T/A
Front Pic
Rear Pic
Front Wheel
Rear Wheel
Side Pic
Enjoy!
So, Wheel Vintiques doesn't have a hubcap solution.
We want to use some sort of cap. Does anyone have any ideas? I've read about some folks welding on the factory hubcap tabs.
Hummm
I have 8 lug Ford Econoline rims on my 53 as these were the only rims I have found that will allow for the stock Chevy caps to fit the center. I screwed on the aftermarket clips sold by Chevs of the 40s and they hold the caps just fine.
1946 1/2-Ton Chevy
Thanks Jim, that is one of the more appealing suggestions I've gotten.
We're really enjoying the radials! I'll post up more pictures when we decide on a solution.
I ordered,the dexstar eight lug wheels for my truck, 16x 6, and I'm now fastening the clips on, but my clips aren't catching the lip on my hubcap. I got these clips from Chevys of the forties, but it's been several years ago. Are there different sized clips available?
Just an FYI, 1990's Suburban wheels will accept the factory caps perfectly. I bought my clips from ClassicParts. The rears bolt right up the fronts of course have to be modified as discussed here many times.
https://www.flickr.com/photos/advance-design_parts_co/8129180933/in/set-72157631867396207
