1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#100981 05/31/2007 6:04 PM
started putting in Dolphin guages on my 53 and discovered they are almost a half inch too small (I know should have measured) But I could have sworn I read in hear about others that did use them. Am I imagining things? I suppose the only option is to get a stainless sleeve but that seems over the top. Desperately looking for suggestions
#100982 05/31/2007 6:15 PM
doc2002002,
I remember something along these lines. If you do a search in this forum using 'dolphin gauges' lots of information pops up....maybe your answer is there.
Stuart
#100983 05/31/2007 11:34 PM
Here's what you need - Dash Inserts from Dolphin.
Go HERE and click on 54 Chevy Truck 5" Quad. Those will take up the half-inch and still leave a bit of room. They also are the only way to mount the gauges in your dash.
I covered mine with leather so they fit even better:
See Here
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#100984 06/01/2007 12:16 AM
Thanks Alan, seems like I didn't order enough stuff....
#100985 06/01/2007 1:38 AM
Hey doc2002002, I am using Dolphin guages in my '48 and they too are to small so I used the original ss trim off of my orig. guages and bent the holding clamps backwards and then used the bracket that came w/ the Dolphin guages and whala.New guages filled the dash with the original trim ss ring. After I bought the guages and the EZ wiring package i was then to poor to pay attention :^)so I did what comes natural for me....make do with what you have. Good luck! Mike
#100986 06/01/2007 1:44 AM
Dam. Alan..your truck is Real real nice.
HURRY UP AND WAIT 55 235 3/4
#100987 06/01/2007 11:08 AM
Thanks, Mike!
Wait'll you see it when it comes back from paint -- it's gone now ... being taken apart and then media blasted ... then it'll be painted 2 colors (my design):
See Picture Here
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#100988 06/01/2007 1:52 PM
Alan, I am ordering my dolphin gauges this week. I like yours but there is a scarcity of Elk around here,except at the local club.
I am using 3 gauges, quad,tach,speedo in a aluminum frame that will be covered by naugahide. We have plenty of those around here :p Will post pics when I get done. Any advice on Dolphin,? where to buy,any problems instaling? I am going with the mechanical speedo. My oil pressure gauge is stil non-electrical. Will it stay that way or do I need a sending unit? will check out the bolt site.
#100989 06/01/2007 2:10 PM
Wow..when I start seeing all these trucks before and afters,,It just keeps me plugging along..It took me a while to tell mtself to Slow down..do it right,..Like I said ...NICE TRUCK ALAN!
#100990 06/01/2007 2:57 PM
THANKS, Mike!
cool
Hey, gazim -- The naugahide will be easier, too ... the elk is a bit thick and I have to shave it down some but it sure is worth it.
I'm looking forward to seeing your pics!!!
My Dolphin install notes can be viewed Here
The clips they give you for mounting are ridiculous - I don't know what they are made of but you can bend and twist them effortlessly! I made new ones that are stronger.
Other than that ... and the fact that the dash inserts are a bit loose-fitting in the dash ... I have *no* complaints.
I have the adjustable speedo and the quad ... 4 years now and they all work beautifully.
I guess the place to buy is from their site.
I *think* you're okay with the oil pressure gauge ... whatever sending units they gave me all worked fine.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
