7 members (55shaker, Shade Baby, Bill Hanlon, Jon G, 78buckshot, TrknGMC, 1 invisible),
109
Mod | | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 46 | After reading with interest about grief with repop tanks I was wondering if anybody had GOOD things to say about a new sender unit from one of the usual suspects - I mean suppliers. While four wheeling last summer the one on the '59 ceased to work. I have run out of gas twice now and it's starting to get embarassing!! I have checked the wires from the sender to the gauge and although some portions of it were 16/2 drop cord the issue seems to be in the sender. I thought I might try to fix the old one but it never was all that accurate anyway. Anyone got experience with this? Thanks - Jeff
220 - 221 whatever it takes
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I installed one in my 57 - I think it was from Carter - works fine, just needed some float arm adjustment [ie: bending] to suit the gauge
Bill | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | If you have a multi-meter you can test your existing sending unit. Put your meter on ohms. Touch the red probe to the wire stud & ground the black probe to the case. Your sending unit should show 0 +/- ohms in the empty position and 30 +/- ohms in the full position. Replacement sending units are $50 so it's worth checking your original out first. You can find multi-meters for $10-15 or less.
| | | | | Joined: Sep 2004 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 46 | Thanks!! You guys are great!!
