| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | Hi all, I just took my springs in to have them looked at. Found some bad news. They're worn out and will need new ones. Here's their response.
,inspected your springs and there is nothing we can do with the existing assy"s ,all of the "11" leafs are .401 material & all the leafs are straight cut,which makes for a stiff ride.New springs we would make out of .401,.360,.323 combination ,leafs rolled and tip inserts,this should make a much improved ride & the "3' drop as well.
The kicker is they want $498 each. Is that the going rate for a single leaf? Any suggestions would be appreciated. | | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | That would be for a complete spring assembly, so $498.00 times 2.
John G 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
| | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | that's correct. I don't think that includes hardware though, like the shackles and pins.
| | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | That's about what I paid for mine 6 months ago. I had a pair of front leaf springs made for my 2 1/2 ton . It actually cost me $800 for 2 complete 9 leaf spring assemblies with bushings & no hardware.
I got these through a friend of mine from the spring shop he does business with. before we got a price I was told plan on spending around $500 a spring. I was able to get these for his cost.
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Yup Fred actually sounds cheep my 2 11 leaf fronts cost me $700 a piece. Front end is now completely new. | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | Thanks you guys. Sounds like I know what I need to do. | | |
