1 members (Gray_Ghost), 79 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#100727 05/12/2007 1:13 AM
Rather than ride someone's post about trying to get a 6 volt gauge run on 12 volts I would like to know. What is a reducer? I know and work with voltage regulators and zenor diodes but this reducer is a question mark. I think they are talking about a resistor. Yes, you get a voltage drop across a resistor but then you must know what R(t) is, which is the "pickle". If it is indeed a resistor how on earth do the guys figure R(t)? Thanks
#100728 05/13/2007 2:00 PM
I do not know enough about electronic to know how they work but here is a link to one being sold and it does give some specs. My personal guess is these devices do not make you gauge read 100% correct they just keep the gauge from buring out and let you know you have some fuel in the tank
reducer
#100729 05/19/2007 4:36 AM
I don't know a thing about electricity, or reducers, but I have been told by people who have used them that they didn't have much success with them. Maybe they were like me, and didn't know how to properly hook one up. Allen
#100730 05/19/2007 7:15 PM
R(t), R= resistance, what is t? I use my original fuel gauge with 12volts, It reads full for a long time, then goes to empty fast. The sending unit in the tank has a variable resistor in it, that needs to be changed to make it work right, to adjust the range of the gauge. Putting a resistor in series doesn't quite get it. You can read the resistance of the sending unit with an ohmmeter. with the gauge disconnected, full tank, and empty tank. divide each of those readings into 12(12volts) to get the current range. Somehow I came up with this chart, I think from studying the reducers available in catalogs, it was years ago. Run 6 volt accessories from 12volt system. 1amp load=6ohm 6watt, 1.3amp load=4.5ohm 7.8watt, 2amp load=3ohm 12watt, 4amp load=1.5ohm 24watt, 8amp load=.75ohm 48watt, 12amp load=.5ohm 72watt. Using a dropping resistor is not efficient and they get hot!
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
#100731 05/19/2007 8:16 PM
A reducer, IINM, is a heavier duty resistor that will reduce the voltage from 12v to 6v.
One would have to be installed before the fuel gauge for it to read correctly, as the gauge is basically voltage meter that has a top end at 6 or 7v.
If you feed it 12v, it certainly won't read correctly, and may burn up.
Yes, a dropping resistor gets hot. It's supposed to. That's the way resistors work. They convert the excess electricity to heat.
#100732 05/19/2007 9:31 PM
A Radio Shack three terminal voltage regulator can be adjusted, with resistors and a couple of capacitors, to provide exactly six volts to the gauge, regardless of the input voltage. Total cost should be less than five bucks.
#100733 05/19/2007 10:32 PM
Or, spend $5.99 plus shipping for a fuel gauge voltage reducer and never worry about whether or not one is truly needed after a 6v to 12v conversion. This is a lot cheaper than having to buy a new gauge.
#100734 05/19/2007 11:18 PM
Beltfed asks a key question at the top of this post. The value of R(t) - the total resistance of the circuit, including the guage windings and the sending unit, must be known if a voltage reducing resistor is being used. Since the sending unit's resistance is constantly changing, there is no one dropping resistor value that will maintain a constant 6 volts at the guage since R(t) is in a constant state of flux.
A mini- DC/DC convertor or, possibly a zener diode, is the only thing that I can see that would do that. My belief is that the "voltage reducers" available from our suppliers are simple resistors that give a "good enough" result even though the voltage is fluctuating at the guage. If someone has one of these on their rig, read the voltage at the guage when it's full, and then again when empty and let us know. My thought is that it won't be 6 volts in both cases.
#100735 05/20/2007 12:22 AM
I've been using the reducer tim posted above for about 24 years.It works great and has lasted a long time.I could'nt tell you any of the electrical values for the resistor.It would be cool to say you built your own .
Good luck !!
1951 3100 Chevrolet
#100736 05/20/2007 1:22 AM
#100737 05/20/2007 1:36 AM
The cheaper one is probably a 6.2 Volt zener.
#100738 05/20/2007 6:34 AM
Yup! Looks like a zener to me - that'll work.
#100739 05/20/2007 12:21 PM
OMG just hearin the word Zener makes me shudder & have flashbacks to the horror of my Dads 67 Triumph motorcycle I restored and fought with the charging sysytem for like ever I finally got rid of that darn thing an went with a electronic upgrade replacement .
1952 Chevy Shortbed
Photos in Photobucket
#100740 05/20/2007 10:59 PM
The Brittish bikes of the 50's - 70's had lousy electronics on them. Lucas wasn't called "The Prince of Darkness" for nothing!!
#100741 05/29/2007 12:46 AM
1 Offline
the zener diode you want is a NTE 5118A 6.V,5W $3 bucks at most electronic supply. or you can buy a "stud mounted" one for $20 bucks that does the same thing. stud mounted one needs heatsink to cool the other style uses air flow around it.
#100742 05/31/2007 8:20 PM
OK..So here is my Question..Does all these posts here mean ...My truck is a 12 volt..But my Guage and sender are for a 6 volt? And some how I must add a Reducer..I burned up my origanal Guage,and got one from Classic..I also am on my 2nd sender...My guage still does not work..and for cryin out loud its only 2 Dam wires..how can I be screwin this up..I was going to get a PO box and use some elses credit card so classic would not think I was Stupid. M /G
HURRY UP AND WAIT 55 235 3/4
#100743 05/31/2007 10:10 PM
Mike wrote:
Quote
grin grin grin
I'm laughing because sometimes the simplest of things bite you. Heck, I can fire up just about any ship in the world and get it from point A to point B, but give me a darn single cylinder 4 stroke lawn mower and you'll see some real cussing at times. Fortunately for me I now have someone cutting my grass and don't have a mower to cuss at anymore.
My 1941 in the Stovebolt Gallery
My Photo Album
But I tried, didn't I? ... At least I did that. RP McMurphy
The past belongs to the future...but only the present can preserve it.
Besides the noble art of getting things done, there is a nobler art of leaving things undone.
#100744 05/31/2007 10:38 PM
My Dog sometimes sits in the truck and watches me work..But when she sees me diggin into the cluster..and reaching for the clutch screw driver...she is out of there.
#100745 05/31/2007 10:40 PM
A replacement aftermarket 12 volt gauge is available,looks like the original.It's available from all the vendors . Depends on how much money you want to spend.
1951 3100 Chevrolet
#100746 05/31/2007 10:49 PM
Ya I realized that after i posted..Double checked what I did by from the Vender I use. It was 12 V They actually take pretty good care of me..replaced a couple things I messed up...
#100747 05/31/2007 11:43 PM
1 Offline
on the hamb this week their is a great tech article on using newer gauge movements (bi-metallic vs magnetic) by using only the stock faces of the gauges (AD TRUCK) check it out. they use a irv from a mid 70's car to regulate the power.
#100748 05/31/2007 11:49 PM
The other thing to consider is power dissapation or Watts. Power is dissapated in the form of heat. That is why the voltage drop resistors run hot. Make sure that whatever system you chhose can carry the power away and maybe even help it with an aluminum heat sink. The formula for Watts is Voltage x Resistance of the circuit.
#100749 06/01/2007 1:27 AM
Can I just by-pass my Guages...and install gauges below my steering wheel? Use the same Oil presser line... ammetter red and Black.. and gas gauge wires and Temp. Guage. In other words use what i have but install updated guages..below my Steering wheel
#100750 06/01/2007 3:11 AM
Mike,why not buy a 12 volt gauge that looks just like your 6 volt gauge ? All of the vendors have them.
1951 3100 Chevrolet
#100751 06/01/2007 6:00 AM
Mike, Don't know if you have an AD truck, but if you do, and you have recently painted the interior of your gauge cluster make sure you have a good ground between the back of the gauge and the cluster back case. I thought I had but ended up taking the cluster apart, sanding the inside of the case where the gauge makes contact and reassembled. Good-luck
#100752 06/01/2007 2:00 PM
I did by 12 volt from CCP...It better be??I am bying out of the 55-1955 book...I,m sure it is, I will have to check My records..I better look into the ground thing. (cluster)Doesnt it get grounded from the Black wire from the Ammeter? May be wrong on that,, When I mention new guage cluster (bypass the stock)...That is going to be a last resort..
#100753 06/01/2007 10:14 PM
NO wire on the ammeter is ever ground. If either side is wired to ground, you will have a fire.
#100754 06/02/2007 12:03 AM
OK..So the 2 wires into the Ammeter are hot..I was just assuming BLACK>>MEANS GROUND> I am wrong..They are real heavey Guage,,That I do Know,I am not Much of a Electrician. But I have to learn. And I have to learn fast.
