| | | Forums66 Topics128,180 Posts1,057,163 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 31 'Bolter | | 'Bolter Joined: Jul 2012 Posts: 31 | How do I hook up the Heater hose for a 1949 Chevy 3100 and if I'm not mistaken doesn't the valve assembly mount to the firewall inside the engine compartment? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It depends on what heater you have. There were dozens of heaters on the market in those days. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Cyril, the basic routing for all heaters is from the engine over to the inner fender and up to the heater tubes sticking out the firewall, and as Cletis says, the valve goes where the particular heater model dictates, ones that didn't include a valve sometimes had one added under the hood, or had a simple shut off in one of the heater hoses at the engine
Bill | | | | | Joined: Jul 2012 Posts: 31 'Bolter | | 'Bolter Joined: Jul 2012 Posts: 31 | Thanks a million. The second pic is the the one. I had the valve assembly rebuilt. So with this pic I should have heat when needed. Just one last question Does it matter which hose goes into the top or bottom of core? | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I have a 49 3100 w/a period correct aftermarket Irvin recirc heater. It is as basic a heater as was offered. There is a cutoff valve mounted at the water pump to allow hot coolant to flow to the heater core in the cab. The premium air flow type heater has a cab mounted temp control cutoff valve. | | | | | Joined: Jul 2012 Posts: 31 'Bolter | | 'Bolter Joined: Jul 2012 Posts: 31 | I guess I wasn't clear. The two hoses that go into the firewall, does the hose on right go to top or bottom of heater core? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | |
