1 members (53 green 1- ton),
110
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | I came across an old Delco Remy finned aluminum coil,with a brass band around the top. Its 12v. Its not a "case" or dress up housing. Its the real coil just the way it was made.(REALLY COOL LOOKING!!) Wish i knew how to post a pic. My question is,,if the coil is good,is it good till it dies? Or do coils get weak and wither away? I wanna use this coil,but dont wanna create problems just to have this thing under my hood. Thanks in advance for your thoughts,opinions,expertise. Marty | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Marty,
Unless it has a 'open' in one of the windings or a shorted winding then it is probably fine. I don't know if a coil such as that would be oil filled or not. If it was oil filled and leaked dry then it's NFG.
It's a pretty simple task to hook it up to a battery and see if it can launch the neighbors Poodle. Generally speaking, a coil will work or won't...no withering or fading into the sunset.
Stuart | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Stu: I must admit that I had wondered that, too. Thanks for the info. Originally posted by atomarc: It's a pretty simple task to hook it up to a battery and see if it can launch the neighbors Poodle. Generally speaking, a coil will work or won't...no withering or fading into the sunset.
Just make sure that you're watching the other end while you're hooking the coil up to the posterior segment of said poodle. Those er... puppies... [snerk] are mean little bastards.  | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I'd like to offer my neighbor's poodle for your coil test! Yapping ##$$&*! | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I do better than Waldo ...Ill offer my MOTHER IN LAW for the test !  | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just my $.03...but it might be easier just to mount the coil on the engine, crank it up and let it run. I've had coils that tested okay but once they were mounted and heated up they tended to go flat. If after running up to operating temperature, your engine doesn't fire up as easily as it did with your current coil.....well, you've got a neat conversation piece for your shop. Hopefully, you won't have that problem. Hope this helps.
Dave | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | I agree with Fla54, coils can deteroate with heat. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Thank you everyone..... Stuart,Brendan,Waldo,SW,Dave,And Beav. Although id love to take you all up on your offers,,I have plenty of territory markin,crap pile leavin, feral cats around here to keep me and probably 20 coils busy for the rest of the year. If anyone wants to see a pic of this really neat coil,,just ask. Ill e-mail you a pic. or two. Thanks again,Marty | | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | I'm curious, because in the early 60's, I remember seeing the finned aluminum heat sinks, but all the ones I saw were purchased in the aftermarket and just slid onto the stock coil. GM has only 2 numbers for 12 volt coils up to and including 1963, The standard coil stamped 087-12v for low perf, The HPerf coil stamped 091-12v for all hi perf.
I know that the above listed HP coil didn't have the fins. This isn't to say that it couldn't have come from a later year. I would just like to know if it is an original from GM and what years it was available. Bob
55 Cameo 396 TH 400 with overdrive 65 Caliente conv 67 BB Caliente conv 67 Mercury 1 Ton 76 GMC 3/4 ton 454ci 84 Buick Turbo Regal
