0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#10045 11/29/2001 2:18 AM
I am planning to get some aftermarket gauges to put in my truck so I can monitor whats going on better. I was wondering: when I get these gauges I am going to get them with an oil pressure gauge, a water temperature gauge, and an ammeter. Since my truck has an idiot light for the oil pressure, do I have to get a different oil pressure sending unit, or do I have to get one that will work with a gauge? :confused:
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
Quote
Yes, your idiot light works from a switch, a guage works from a sending unit, 2 different units, but can be done.
1956 GMC 1 ton Napco 4WD
get a T fitting or a twin at a 45 deg from each other, plumb into orignal hole and wire approately. Done it before with no problems. Just had to find right fitting combo's
Brad
gmcfan I have a question for you: Are you getting mechanical or electric gauges?
I would suggest mechanical.
Next regarding the Idiot light. If you go to your local ma and pa auto parts and look thru the buyers guide to their ignition line they should be able to select a sending unit for your light that will turn on at your prefered Oil preasure. Meaning the original sending unit may not turn on the light till the preasure drops to say 5 lbs. Well if you want it to turn on at 8 or 10 or higher just look thru there catalogs and I am sure you will find something. However it may be a different size fitting but that is a simple fix.
Good luck.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
I was thinking electrical, but is there any advantage to using mechanical? More reliablility? Lower cost? :confused: smile
Jonathan S. Keffer
