| | | Forums66 Topics128,104 Posts1,056,201 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10045 11/29/2001 2:18 AM | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | I am planning to get some aftermarket gauges to put in my truck so I can monitor whats going on better. I was wondering: when I get these gauges I am going to get them with an oil pressure gauge, a water temperature gauge, and an ammeter. Since my truck has an idiot light for the oil pressure, do I have to get a different oil pressure sending unit, or do I have to get one that will work with a gauge? :confused:
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht- Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
#10046 11/29/2001 6:52 AM | Joined: Nov 2001 Posts: 9 New Guy | | New Guy Joined: Nov 2001 Posts: 9 | Originally posted by gmcfan: I am planning to get some aftermarket gauges to put in my truck so I can monitor whats going on better. I was wondering: when I get these gauges I am going to get them with an oil pressure gauge, a water temperature gauge, and an ammeter. Since my truck has an idiot light for the oil pressure, do I have to get a different oil pressure sending unit, or do I have to get one that will work with a gauge? :confused: Yes, your idiot light works from a switch, a guage works from a sending unit, 2 different units, but can be done.
1956 GMC 1 ton Napco 4WD
#10047 11/29/2001 9:15 AM | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | get a T fitting or a twin at a 45 deg from each other, plumb into orignal hole and wire approately. Done it before with no problems. Just had to find right fitting combo's Brad | | |
#10048 11/29/2001 2:10 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | gmcfan I have a question for you: Are you getting mechanical or electric gauges?
I would suggest mechanical.
Next regarding the Idiot light. If you go to your local ma and pa auto parts and look thru the buyers guide to their ignition line they should be able to select a sending unit for your light that will turn on at your prefered Oil preasure. Meaning the original sending unit may not turn on the light till the preasure drops to say 5 lbs. Well if you want it to turn on at 8 or 10 or higher just look thru there catalogs and I am sure you will find something. However it may be a different size fitting but that is a simple fix.
Good luck.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#10049 11/29/2001 8:05 PM | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | I was thinking electrical, but is there any advantage to using mechanical? More reliablility? Lower cost? :confused:
Jonathan S. Keffer
