2 members (kbenz, Gib70),
166
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 23 New Guy | | New Guy Joined: Dec 2013 Posts: 23 | So I have researched my engine number and I don't seem to see one that looks like my number. The engine I know is not the original engine and is a rebuilt installed around 1982. Any suggestions on this number would be helpful. Below is the pic. flickr Thanks guys paul
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Your link is to a sign in page. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Engine serial number F 7 31 B F = Flint MI plant 7 = July 31 = 31st B = Powerglide-equipped car engine
To get the year of the engine, you will need the other codes, found at the locations shown in the link I posted above. | | | | | Joined: Dec 2013 Posts: 23 New Guy | | New Guy Joined: Dec 2013 Posts: 23 | The "1" that you have in "31" looks like an "i" in the Flicker photo that I have in my second post. Pretty sure it is an "i". Looked at the link under your name and the location that I got this number from is the location labeled "engine serial number". Which number will tell me what this engine is ie 216,235?? Maybe the casting codes??
| | | | | Joined: Dec 2013 Posts: 23 New Guy | | New Guy Joined: Dec 2013 Posts: 23 | From what I can tell is all I have is an engine serial number prefix no actual serial number. I'll have to get down and see the casting numbers. From this link it looks like it would be a 235cu and I guess the "i" would be a "1" . Great site BTW. http://www.1954advance-design.com/chev-specs/1961-c-ser.pdf paul
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Paul,
That engine code format started in 1957 (57-63).
All Powerglide transmissions were matched up with 235s (high pressure 235s from 1953 onwards; low pressure 235s from 50-52)
The letter I and the number 1 were often interchanged when a code was stamped.
| | | | | Joined: Dec 2013 Posts: 23 New Guy | | New Guy Joined: Dec 2013 Posts: 23 | Great, thanks appreciate it and the link. Now I can move forward for parts.
Paul. | | |
