12 members (Gdads51, greenie-reddy, Simso, Joe H, 1955 1 Series, Southerntruck, Gib70, 3B, Peggy M, Oswald, Jon G, 1 invisible), 172 guests, and 1 robot.
Topics128,103
Posts1,056,183
Members48,436
So I have researched my engine number and I don't seem to see one that looks like my number. The engine I know is not the original engine and is a rebuilt installed around 1982. Any suggestions on this number would be helpful. Below is the pic.
flickr
Thanks guys
paul
Your link is to a sign in page.
1951 1 Ton Completed
Sorry about that. Here it is. http://www.flickr.com/photos/miltown/12252672545/
Number reads F73IB thats all.
Engine serial number
F 7 31 B
F = Flint MI plant
7 = July
31 = 31st
B = Powerglide-equipped car engine
To get the year of the engine, you will need the other codes, found at the locations shown in the link I posted above.
The "1" that you have in "31" looks like an "i" in the Flicker photo that I have in my second post. Pretty sure it is an "i". Looked at the link under your name and the location that I got this number from is the location labeled "engine serial number". Which number will tell me what this engine is ie 216,235?? Maybe the casting codes??
From what I can tell is all I have is an engine serial number prefix no actual serial number. I'll have to get down and see the casting numbers. From this link it looks like it would be a 235cu and I guess the "i" would be a "1" . Great site BTW.
http://www.1954advance-design.com/chev-specs/1961-c-ser.pdf
paul
Paul,
That engine code format started in 1957 (57-63).
All Powerglide transmissions were matched up with 235s (high pressure 235s from 1953 onwards; low pressure 235s from 50-52)
The letter I and the number 1 were often interchanged when a code was stamped.
Great, thanks appreciate it and the link. Now I can move forward for parts.
Paul.
