| | | Forums66 Topics128,022 Posts1,055,382 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Long story, Last fall somthing shorted out and the wires from the alt. to the ammeter and from the ammeter to a relay then to the battery got hot. I replaced them but prior to the replacement my dash lights stopped working, the gas gauge jumps past full with a loud click. the radio doesn't work. All these things happined about the same time, other lights work and truck starts ok. On checking the fuses it appears that only 1 circut is hot, the juice just never seems to get there from the ign. switch, which is new. HELP | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | wish I could help Zimmer, looks like you have a electrical problem for sure...............I just noticed on a post that west-auzzie..... is a automotive electrican.......maybe he can help just curious, is this the same truck you were going to give me a deal on..  Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | If this is your 62 pick up,I would pull the dash cluster out and check for a melted harness.It will be easy to trace with an Ohm meter (Battery Disconnected First !!!)to locate the short.The fuel gauge goes past full with an open circuit and to empty when the sender lead is grounded provided there is power to the other side of the gauge.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Apr 2007 Posts: 20 Member | | Member Joined: Apr 2007 Posts: 20 | Sorry guys been putn in time on the down time bench and re-chargn my batteries,best i can tell just now is that gtow69 is on the money,further to that could you also mark the wires on the ammeter and remove them then check that you have a circuit through it and not to ground (body of the truck).One issue i have all ways had with ammeters is that although they give a better indication of current flow they are generaly un protected (fused) and once upgraded from a generator (approx 20-30 amps output) to an alternator (any where from 35-140 amps output)the potential for the insulators on the bolt posts at the rear of the ammeter to fail thereby allowing it to short out on the body of the meter are very real,this is only a problem due to the fact most automotive ammeters are only good for approx 60 amps,so if you have to jumpstart your truck due to a flat battery, once the alternator commences charging it will have a big output(nearly max output) until the regulator tappers it off if the said insulator's hold up all is good if not,well you don't want to know if not,i wish i could just drop in and do the repair's for you any chance i get to spend "quality time" with a truck is o.k. with me.good luck and don't hesitate to get in touch just bear in mind im half a world away and i work shifts so some times you get lucky other times you don't. just on the jumpstart thing it is o.k. to jumpstart but it is a good idea to leave both trucks linked for a few minutes to allow the regulator to tapper off.Hope this helps.
Where there is a will, there is a relative!
The 4 stroke cycle(suck,squeeze,bang,blow)
| | | | | Joined: Apr 2007 Posts: 20 Member | | Member Joined: Apr 2007 Posts: 20 | If you could find away to send a wiring diagram to me i would love to help, i don't like these issues beating me.the problem i have is i have seen very few of these trucks and can only work with what i gather off comments on the forum.good luck once again mate
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | thanks Aussie and Gtow, I had a melted harness but replaced the two wires as stated originally. The battery doesn't run down and most gauges work. It just seems like I lost juice to the fuse box. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | forgot to add, windshield wipers, cigar lighter, hearter blower, not working either | | | | | Joined: Apr 2007 Posts: 20 Member | | Member Joined: Apr 2007 Posts: 20 | gazim west here mate,what truck are we looking at here ?
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | 62 chev with quite a few modifications, probably find pics in the gallery. under gary Zimmerman's 62 | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | want photos of Zim's truck click here and HERE Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Thanks Fred, covered for me again. | | | | | Joined: Apr 2007 Posts: 20 Member | | Member Joined: Apr 2007 Posts: 20 | Mate we need to get that painted pony back out on the black top,i am looking for a diagram but as yet have not found one ,don't lose faith in me yet.
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | LOL at the painted pony. I have a diagram for the older trucks but havent figured out yet if if covers mine. Kinda doubt it. Thanks | | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | are you sure you only damaged two wires?
"It ain't a truck if you can't hose out the cab."
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | hey Zim, I have been looking for some on-line diagrams for your 62 but no luck... just a tip, you might pm these last two guys from a previous post that have a 62 and see if they have anything to offer.. here is the post Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Chester, I have only found the two so far. Stupid question, but do I have a voltage regulator on my truck if I am using a altenator? The schematic I have for the older trucks show one. but I can't find anything like that on mine and I did look well. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | good Idea Fred, will get on that right away. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Replacing Light switch tomorrow will advise. | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Generators and early alternators used external voltage regulators; more modern alternators have voltage regulators integrated in the alternator. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Light switch didn't fix anything Thanks baldy, clears that up at least, I have no voltage reg. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Gazim,check your fusible links by pulling on them.If they are bad(open circuit)they will stretch like a rubber band and not supply voltage to the one side of the fuses they power up.A sure sign is that you have no power on BOTH sides of some fuses.
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | These(60-66) have no protection before the fusebox, what has likely burnt up is the ammeter shunt wiring, usually(& melting a nearby wire also) near the inst panel. These two black w/white tracer wires run from the horn relay to the inst panel, the other runs from the panel tot he starter relay. Pull your inst panel & check(untape & inspect)the harness behind it. The big pink wire from the ign. switch feeds the fusebox accessory side IIRC. You could also pull the fusebox & see if something is up there. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Will try that this morning(its raining all day) I replaced the wires from the starter and alt' to the ammeter already, they had fried but not failed. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Going to pull this thread tomorrow. Got everything fixed except the heater. Taking it out for a trial run this afternoon. I don't really know of any one thing that worked, but all together, its fixed. Thanks guys for all the help | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Well crap, everything worked for a while. now ammeter and turn signals on the fritz | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Keep a fire extinguisher handy! Stuart | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I never intended for this to go on this long but **** happins, fixed the turn signals but the ammmeter refuses to cooperate. it will move if it is tunked with a screwdrivr to get the proper reading. but what u read last will stay there till you hit it again. Need a new one? or did I screw somthing up with my re-wiring?? It worked for about the first 10 min ok. | | |
