3 members (Otto Skorzeny, homer52, 1 invisible),
70
Mod | | | Forums66 Topics128,083 Posts1,056,326 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Well folks, my original MC is leaking again. I have rebuilt it once, a while ago, and now it is leaking again. I don't think another rebuild will do the trick, so I am thinking of converting to duel MC, power and disc. I have been reading the archives and seen come good info. I was wanting to know anyones experience with the different kits and ya'lls suggestions. I came across the kit on Performance Online and it looks like a good kit with everything I would need. Are there any issues with the stuff clearing a manuel transmission? Thanks for info and advice!
58' 3200 235 3-speed/OD
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Manual transmission... no, ebrake cable... yes | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Thanks BigBad. In theory rerouting the cable will be easy, but we all know about theories on these trucks lol.
| | | | | Joined: Oct 2006 Posts: 76 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 76 | LOL at the theory line. Found it to be very true. In theory it will only take a few minuets or cost only a few bucks. We all know how that gos. | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | I have see a few guys stories were they only installed a brake booster and left the drum brakes. They say it works great if your not racing around and you dont haul much. May save you a few buck if you dont want to do the hole conversion right away. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | My 58 had all that on it when I got it, but the pedal was low & soft. It uses the small bolt pattern 5 hole & I have a Firebird rear end. I put a checkvalve on the rear & bled it all real good & they work real good now. If I was to do it myself I think I would do like Grandpa says & leave the drums. Unless you are going to do some serious driveing thats all a guy needs. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If any of you drum enthusiasts would drive my '56 with drums then drive my suburban with front discs I think you'd have to admit that even though the drums are "adequate", you'd much rather have a truck that stops like the burb does. | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | I agree with Cletis. I'll take the disc brake conversion anytime. Of course not everyone has to deal with the Honda crazies on So Cal freeways. Before you do the conversion, plan it out. In most cases you will have to replace the wheels. Some kits for 6 lug use your existing hubs so you probably need new bearings. The kit I used has 5 lug rotors and I had the rear axles redrilled to match. Mine has the booster/master under the floor and there are no clearance issues with the 3 sp OD trans. Fred
| | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | I would like the disk someday, but money it the issue. I agree with all of you and think I may just go the powe drum route. My 66' Fleetwood Caddy has power drums and stops fine. I always drive according to what I am driving. I drive my dad's sky roadster different than my old truck. Don't push your equipment past it's limits.
| | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | I have gotten my new Duel MC and Booster. I think I have what I need to swap, but I remembered reading about check valves. Will I need these on a drum/drum set up? Or, do you only need them on the disc/drum setup? Or, do you need them when the MC/booster are mounted under the cab? Thanks for the help folks and if I need them where is a good place to buy from? Thanks again!
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I switched to a dual master on my 55.2. Cleared the tranny with room to spare. The e-brake cable needed to be modified. I had to move the little round junction thingy back about 6 or 7 inches. I also had to drill a new hole in the ebrake arm. These two images show how that junction interfers with the master cylinder. Unmodified Unmodified Unfortunately, I don't have a picture of the modified position but it is 6 -7 inches back. I also had problems with the cable interfering with the transfer case, which you will not have a problem with as yours is a 2wd. | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | jomichael- Thanks for the info! That looks like the exact setup I bought. Did you have to use some residual check valves to stop bleed back from happening?
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Not sure what bleed back is, but mine is drum/drum since I have original 4wd. It is probably different than drum/disc. You can see from the photos that you have plenty of room to add anything in order to take care of that problem. What is bleed back? The higher pressure of discs vs. drum? If so, I bet that is taken care of internally. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Most master cyl. designed for drum brakes have the check valves in them. You might be able to see them Or poke something in & feel them. They go right behind the brass insert in the outlets. If it does not have them you need to mount some inline. They are available at Summit or Jegs, They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2013 Posts: 19 New Guy | | New Guy Joined: Sep 2013 Posts: 19 | Id also really like to know this to. I just ordered my kit. I have wilwood disc brakes and lines coming for my new rear. Still running the drum's on the front. Now is it mandatory to go to a 2 chamber master cylinder? Im not going with booster like OP. But curious on the valves etc. Been reading a bit about that but can't find a solid answer either. | | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | You will need a 2 psi residual valve for front and a15 psi residual for the back if mc is mounting on frame .. | | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | That's when the the mc is lower than calipers fluid can go back into mc and overflow it that's why u need residual valves to prevent that | | | | | Joined: Mar 2006 Posts: 143 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 143 | Sal, If he has discs on the BACK and drums on the FRONT-shouldn't your figures for pressure be switched? | | | | | Joined: Jun 2012 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 60 | Sal, If he has discs on the BACK and drums on the FRONT-shouldn't your figures for pressure be switched? Now thats a combination I never would have thought of
Allan 1946 GMC 1949 Mercury M68
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I wouldn't advise it. I have never heard of a factory set-up like that and I'm sure there is a reason for it. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sounds like it'd be scary with hard braking, the front wheels provide 60-90% of braking  Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I wouldn't advise it. I have never heard of a factory set-up like that and I'm sure there is a reason for it. I have owned a vehicle that did have a setup like that, with drums in the front a disk in back. However, it was a Yamaha Moto-4 ATV, not a street driven truck. I'm in 100% agreement, do the brakes right, with disks on the front to match the rear, as well as the proper master cylinder.
Bill Burmeister | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Discs are a better system. Putting discs on the rear with front drums would cause your rears to do more of the braking, which would be scary. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Your first post says you were thinking of dual, power, disc. Then it sounds like you purchased dual, power and are staying with stock drums. Assuming I got that right, and you bought from a well known vendor, they would be the ones who would advise on residual valves, If you told them what you are doing they should have sent the necessary parts in the kit (IF you bought a kit).The kits come with different valving depending on drum/drum, disc/drum or disc/disc. Just remember, there are three components we are talking here. The dual MC is for safety, the power booster is for brake pedal pressure and the disc is for safety/quicker stops. Put them all together and you have a great safe combo that will stop quicker with way less foot pressure. Dual, Power, drum brakes are not all that great of an improvement in actual stopping ability. I don't think you will notice any change except foot pressure. Boosters are kind of for disc brakes anyway. You will really, really like the Power front disc brakes. You will find a great improvement as Cletis and others indicate. I have done that kit on several TF trucks.
Residual, or check valves, are used to keep slight pressure on drum brakes because the return springs will pull the shoes too far away from the drum unless you keep adjusting the shoes. Also fluid can't return to the MC with a slight pressure always applied and they being a check valve. They are used on disc but meant for drum. Different pressure values are used for front and rear. The proportioning valve is used to apply less pressure to the rear brakes. They require less force than the front and, as said, the front do more stopping than the rear. (weight and weight shift)
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Your first post says you were thinking of dual, power, disc. Then it sounds like you purchased dual, power and are staying with stock drums. Assuming I got that right, and you bought from a well known vendor, they would be the ones who would advise on residual valves, If you told them what you are doing they should have sent the necessary parts in the kit (IF you bought a kit).The kits come with different valving depending on drum/drum, disc/drum or disc/disc. Just remember, there are three components we are talking here. The dual MC is for safety, the power booster is for brake pedal pressure and the disc is for safety/quicker stops. Put them all together and you have a great safe combo that will stop quicker with way less foot pressure. Dual Power, drum brakes are not all that great of an improvement in actual stopping ability. I don't think you will notice any change except foot pressure. Boosters are kind of for disc brakes anyway. You will really, really like the Power front disc brakes. You will find a great improvement as Cletis and others indicate. I have done that kit on several TF trucks.
Residual, or check valves, are used to keep slight pressure on drum brakes because the return springs will pull the shoes too far away from the drum unless you keep adjusting the shoes. Also fluid can't return to the MC with a slight pressure always applied. They are used on disc but meant for drum. Different pressure values are used for front and rear. The proportioning valve is used to apply less pressure to the rear brakes. They require less force than the front and, as said, the front do more stopping than the rear. (weight and weight shift) The residual valve on discs is a lower pressure than for drums also, so that you don't essentially lock up the front brakes. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Someone correct me if I'm wrong but I think for drum/disc set up the supplier usually recommends 10lb. and 2lb residuals for the front......that is what PirateJack's brochure said when I read it. I put my m/c and booster under the floor while I was putting in my new "system". | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | ^ You are correct. 10lb for the drums and 2lb for the discs. I'm in the process of installing the CPP conversion on my '51 now. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I just did that conversion for the AD. Big discussion on it in Drivelines. I will be interested in what you think. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | ...I will be interested in what you think. Who, me? I already know I'll like it. As others have said, properly maintained drums are adequate, but discs are superior. I was initially just going to switch to a drum/drum dual MC but the effort to go to discs is the same. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Read the thread in Driveline about it. I know I will like it too, but there are issues it wouldn't hurt for anyone to know. Yeah you!  There pics in the photobucket for mine. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Haha. Ok, I'll take a look at it. What kid did you use Deve? Mine is the CPP 6 lug I bought the residual valves and some "universal" line from the proportioning valve to the T's but I'm wondering if I should upgrade my lines running from the T's to each wheel too. If so, what size line for front and rear? | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | mine is the 6 lug kit. I got the Dual MC with the proportioning valve for rear drum/front disc. Because I have an overdrive transmission, there were clearance issues so I had to make my own lines from the prop valve to the MC. I got the MC bracket WITH prop valve bracket that is just below the MC.
At the brass T that is located approx. adjacent to the front crossmember, I disconnected the rear lines and capped it off to separate the front from the rear, then ran my rear lines to the front side of the transmission crossmember, across and to the prop valve. The front disc brake lines seem to be 3/16 to work best. My stainless lines from a few years ago are 1/4 so I had to get some adapters at the front hoses for the larger lines to work. So, if you are plumbing everything all over again, use 3/16 for the front, 1/4 for the rear. The line that runs across the rear end from rear wheel to rear wheel is 3/16.
I wont use stainless again because there is a much nicer nickel copper line that shines up about as nice and bends and flares much nicer while still having the corrosion proof qualities of stainless. You can always look at the pics in the bolt bucket to see how I did it. If you need pics of something else, lemme know. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Also, I just got my test wheel in today from Wheelsmith. Havent had a chance to evaluate it yet. The stock rims especially if they are 15 inch will not fit over the new calipers. So, remember that you have other choices to make.. like what new rims to purchase. Disc brake rims are shaped differently than drums.
So, you can get two new wheels, but then you have to have TWO spare tires. One for the front and one for the back, or, the new disc profile wheels work fine on drum brakes, so 3 new wheels is the most sensible. The cost for my stock looking vintage wheels was $90 a wheel without paint. Then, their wheels don't have clips for the stock hubcaps so they will modify your hubcaps or you can purchase new ones from them. With the hubcaps, about $120 a wheel. It never ends does it? LOL!
Since I a very picky and these wheels DO look a little different than the originals if put side-by-side, I got 5 new ones so the set is the same.
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I have the same proportioning valve and bracket and plan on running my own lines from the valve to the brass T's but was hoping to use a pre bent line from the T's to the flexible lines. Spoke with Van at CPP today and he said not to worry about the line size for the front. 3/16" is all that is necessary for the discs, so the larger stock drum lines will work fine and since I'm using the residual valves they'll stay at the correct pressure. ...there is a much nicer nickel copper line that shines up about as nice and bends and flares much nicer while still having the corrosion proof qualities of stainless... Where did you find the nickel copper line? ...disc profile wheels... I have the stock 4x16" wheels and I was planning on using a 1.5-2" spacer on the front and something a little larger on the rear. So I'm not too worried about the wheels clearing. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | That's when the the mc is lower than calipers fluid can go back into mc and overflow it that's why u need residual valves to prevent that I just read this. The residual pressure valves are there so that when you push the pedal, you're not pushing the piston on the drum or disc brake all the way from it's minimum position. This is to make up for pad or shoe wear. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | You can get your nicop lines at the Brakequip store. I am sure there are lots of other places to get it.
Isn't Proportioning Valve and Residual Valve the same thing? I have NO idea. Learning this as I go. Even with the dual MC located below the floor it is still higher than the calipers. Can't see where the worry of backfill would apply. | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | You can get your nicop lines at the Brakequip store. I am sure there are lots of other places to get it.
Isn't Proportioning Valve and Residual Valve the same thing? I have NO idea. Learning this as I go. Even with the dual MC located below the floor it is still higher than the calipers. Can't see where the worry of backfill would apply. think of parking on a hill..... | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I know what the prop valves primary purpose is, but doesn't it also keep backfill from happening? A long time ago on Horsepower TV they had a tip on inline residual valves. I think they were pushing something from Summit Racing. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The residual valves maintain a minimum constant pressure in the system, for disc brakes it keeps enough pressure to keep the caliper full of brake fluid but not enough that the brakes drag. If they are not installed your master cylinder will not have enough capacity to apply the brakes with one stroke of the master cylinder. The proportioning valve is used to set the amount of fluid that is sent to the rear brakes vs the front brakes. It helps prevent rear brake lock up. On performance vehicles a proportioning valve is used to adjust the amount of brakes to either the front of the vehicle or the rear of the vehicle. It is used as an aide to get a car through the corners faster by helping steer the vehicle through the corner by using the brakes. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The disc brakes on a 47-55 using the standard kit, the calipers are about 3.5 inches lower than the lowest point on the master cylinder and about 1.5 inches lower than the prop valve when installed just below the MC. So, do I need still need residuals? I still wonder if there is any worry about backfill since the fluid would have to get thru the prop valve first. Maybe I am overthinking it. Wouldn't be the first time. | | |
