4 members (tclederman, Gray_Ghost, Otto Skorzeny, 1 invisible), 100 guests, and 1 robot.
Topics128,132
Posts1,056,386
Members48,441
#1002587 01/28/2014 8:58 PM
I am looking into getting a new floor. Most of the companies sell the whole floor with seat riser. Almost all of them are on back order. I see LMC has one that says it is for 49-55.
I thought the only difference between 47-48 and 49-54 was the gas tank straps in the back behide the seat? Anyone know why the 49-54 would be any different besides the gas tank mounting? thanks in advance. Having a terrible time finding a floor in stock anywhere. If you know anywhere they are in stock please let me know
1948 Chevy 5 Window 1/2 Short Bed
1969 Dodge Coronet SUPER BEE 383 Ramcharger
1949 Bentley Mark VI Standard Saloon
http://imageshack.us/photo/my-images/695/dsc04398mm.jpg/
There is a significant difference in the early 47-48 cabs verses the 49 when the tank moved to the inside on pick-ups. I am sure that is the reason.
Do you know what the "significant difference is by chance?
The rear cab mounts changed in both style and position. Look closely at the body section in the shop manual.
You Tube
There is also an inner sheet liner with an integral structure that encloses the center shackle. This liner runs from where the existing liner is above the belt line all the way to the floor. It takes up much of the room where the tank sits and was removed when the tank and body mounts were relocated in 1949.
Thanks. Does anyone know where I can get the correct one for 1948?
I think you will only find one complete floor section offered by the vendors, usually your option is with or without the riser. I am sure it can be made to fit like any of the sheet metal parts available for these trucks.
