2 members (JoergK., TUTS 59),
120
Mod | | | Forums66 Topics128,195 Posts1,057,378 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | Something I did not fully plan for in taking on this project was the amount of crud I'm going to create.
Looking for some insight on how you clean parts in YOUR garage, and how do collect and dispose of oil, grease, crap, misc fluids.
Furthermore, what are your favorite products/ solutions for different kinds of cleaning and degreasing tasks?
1951 3100
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | The hardest thing to get rid of the right way is antifreeze,here anyway lucky for me my son in law owns a garage and has a service that he pays to remove.One thing you should do is get a solvent tank ,You'll be able to clean you're parts for a long time. If you chose water based solvent it will say where and how to dispose ,I use mineral sprits and when I'm done I add it to my waste oil and bring it to the garage or Advance auto parts takes it to.
Pete | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Pete: Generally, adding solvents/gasoline/etc to waste oil is a big no-no. Some places I take my waste oil will actually smell the oil to ensure it has not be mixed with gasoline/solvents. So, what to do with it? I also use mineral spirits in my parts cleaner which is located outside. I do an initial fill whenever I have large cleaning projects and then let evaporation empty the tank before I clean it up waiting for the next project. Once the level goes below the pump, I simply dunk the parts, brush, dunk, brush, and so on. I do the same with my spray gun cleaning solvent. I clean my guns in a 5 gallon bucket and let evaporation get rid of the solvents. The paint stays in the bucket and hardens.
With that said, I know the environmentalists are not happy with my approach, but luckily there are no laws against what I am doing in my area. | | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | The hardest thing to get rid of the right way is antifreeze,here anyway lucky for me my son in law owns a garage and has a service that he pays to remove.One thing you should do is get a solvent tank ,You'll be able to clean you're parts for a long time. If you chose water based solvent it will say where and how to dispose ,I use mineral sprits and when I'm done I add it to my waste oil and bring it to the garage or Advance auto parts takes it to.
Pete You have a recommendation for a solvent tank? I am cheap.
1951 3100
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | All good advice. I would only add that your community or state may have policies in place for convenient disposal or collection of parts cleaning waste. Most state laws require that whoever sells cleaning solutions, oil, filters and antifreeze are required to take back any waste such as mentioned Advance Auto does.
Drew
| | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | I've got my eye on an unused blue plastic kiddie pool that's just taking up space in my garage.
(Of course it's use as a kiddie pool would be never more)
1951 3100
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Although it is getting harder to find in bulk unless you live in a rural area, kerosene, works greaT as a solvent. It's as cheap as any of the solvents, it has one of the highest flash points of any of the common solvents which makes it quite safe. Easily disposed of at any garage that has a waste oil burner. Gunk tanks are cheap at Harbor Freight, have fused lids in case of fire and most come with a pump that works for a couple of weeks. Never been able to fine a dump site for anti-freeze, wish I had a friend like Pete. Grease is easy, into the garbage bag with the oil rags. Drain oil to the oil burner garage tank, most auto parts stores or oil change stations also take it.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2013 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 61 | I've had really great luck with BioCircle at work. It uses bacteria that break down grease so it's water-based and solvent free. I'm not sure that you'd find one affordable enough for home use though. You might be able to rig something up if you bought just the fluid though.
Whenever you leave behind failure that means you're doing better if you think everything you've done has been great you're probably dumb -Louis CK- '53 GMC | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I have a small wash tank with a pump. Don't use it very much as a pressure washer, or hose pipe, and simple green clean stuff and then into my blasting cabinet.
I have a 10 gal heavy duty plastic jug. I pour all my oil changes and other such liquids into it and take to a recycling place....and the spirits in the cleaning tank take care of themselves. As Denny mentioned, the gunk can go into a plastic bag and its gone.
For what its worth. Advance wants everyone's used oil anyway. It brings them .50 per gal. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | In my area waster oil furnaces are popular and those guys are always happy to get drain oil. I take my used antifreeze to another shop that has an antifreeze recycle machine. They use the recycled antifreeze for topping off vehicles in for service. They don't use it in place of virgin antifreeze for a dry system. Dirty rags and grease and grim go into a garbage bag and off with the garbage man. Oil filters go along with the drain oil and the guys have an oil filter crusher. It gets most of the oil out and it goes to the drain oil tank and the rest of the filter goes in the scrap iron pile that goes to the scrap guy who takes it to the smelter to make rebar. | | |
