| | | Forums66 Topics128,159 Posts1,057,033 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | How hard is it to swap one 4 spd. Transmision for the same on a 39 truck. I bought another transmission and had it checked out. Now I need to install it or have the shop install it ($450). The truck has an enclosed drive shaft and the transmissions Are the same. I've never changed one out and was wondering how hard it is? Thanks Tom
Tom
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | | | | Joined: Mar 2011 Posts: 153 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 153 | You could probably do it yourself in a day. Rent a transmission jack or modify the saddle on your floor jack to do the lifting. I've found the hardest part is to line-up the splines when inserting the transmission through the clutch- requires a lot of jiggling to get it just right. It isn't rocket science if you have a shop manual to help you but it can be a good physical workout. Good luck!
1946 Chevy pickup, 1948 Chevy suburban, 1950 Chevy pickup, 1952 GMC pickup, 1957 Chevy pickup, 1939 Chevy pickup
| | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | Thanks for the replies! I will give it a try.
Tom
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | At the link that Achipmunk provided above, are 1938 and 1941 Shop Manuals. The instructions for removal/replacement should be the same for yours. Guide pins are referred-to for removal.
Those guide pins are invaluable for installation (and, safe removal). They not only set up the correct angles, but they allow you to more easily rotate the transmission shaft (from the ear) so that you can to line up the splines on the front shaft to the clutch (as noted by Pinetree, above).
Buy some bolts of the correct length and cut off the caps - these are your guide pins. The two bolts need to be long enough for the transmission to "sit" on them as you slide in the transmission (using a jack until the transmission is supported by the guides).
| | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | not hard at all. i did it myself and it came out fine. remove floor pan, jack up truck, disconnect drive shaft plus yoke, then remove the tranny..about a hour or so of work. | | |
