2 members (VicZ, doyle1950),
143
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Need a picture of a 53 3100 pass side defrost vent. I can not get my new glove box to fit as it hits the defrost vent.My pot metal vent points straight down and searches don't turn up pictures only SMILE.
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Brad's bent defroster inlet vents look like vents shown in the 1953 and 1954 truck heater installation instructions. They are angled (not straight) and the diameters of the inlet holes are different. The hose-inlet on those vents are directed towards the firewall, as shown in this 1951 installation manual for air flow heater and also shown here for recirculating heater. The smaller diameter vent goes on the passenger side. Brad, Do you know if anyone sells reproduction spring clips (one is used on each inlet vent)? Thanks, | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Tim,
I have not seen those clips reproduced as of yet. Maybe someone will catch the thread that has seen them somewhere?
| | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Thank you Brad and Tim. My 53 has the bottom one in Brad's post. I will post in the wanted forum for a vent.
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Tim:
My truck did not have defroster vents, so I found a pair of cast metal vents via Ebay. But, they did not have the clips so I simply used small machine screws and bolted the vents to the dash (using existing holes). However, I do have one of those clips in my fastener bucket and have no idea where it came from or if I will ever use it during restoration.
