2 members (Otto Skorzeny, dt235sd), 122 guests, and 1 robot.
Topics128,052
Posts1,055,719
#1000152 01/18/2014 7:13 PM
I have a 1960 Apache with a big window, which is rusty around the windshield, inside and out. I found 2 replacement cabs in Arizona. One is a small window and real clean for 650. Next is a big window, but with a cut up radio opening, and dents in the roof skin, otherwise clean, for 400. Is it cheaper to fix the dents and dash, or is it cheaper to do a big window conversion on the cleaner cab? It's really important to keep the big window option. Thanks for any suggestions.
The rear window conversion is an easy one. Just remove the inner panel from a donor truck and weld it into the small window cab. Then cut out the excess, Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
