6 volt turns "slow" compared to a 12 volt system.
It is plenty if all is in good order. One of the first things most people do to try to start a vehicle that has been sitting is move the distributor and mess up the ignition timing. Check the timing and dwell, make sure you are getting spark through the plugs, and make sure fresh fuel is getting to the carb.
