7 members (baldeagle, Hanks custodian, Guitplayer, Otto Skorzeny, Maybellene, Hotrod Lincoln, 1 invisible),
43
Mod | | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99882 03/15/2007 1:21 AM | Joined: Mar 2007 Posts: 4 Junior Member | | Junior Member Joined: Mar 2007 Posts: 4 | I am new to this truck. It was my grandpas truck and I finally got it from my cousin who has had it for the last 18 years. Anyway, He said that it was running a couple of years ago, but I bought a new battery, put new points in it and I try to start it, but it seems really slow trying to start. Still the 6 volt system.Is it supposed to turn over real slow like that or is it supposed to turn over pretty fast? I couldnt get it started....any suggestions??
1951 Chevrolet 3600
#99883 03/15/2007 1:46 AM | Joined: Aug 2006 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 26 | 6 volt turns "slow" compared to a 12 volt system.
It is plenty if all is in good order. One of the first things most people do to try to start a vehicle that has been sitting is move the distributor and mess up the ignition timing. Check the timing and dwell, make sure you are getting spark through the plugs, and make sure fresh fuel is getting to the carb. | | |
#99884 03/15/2007 4:44 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Welcome to the Stovebolt. I'm moving your post to the Electric Bay to make it easier for others to "search" for later.
Grounds are what causes most problems with 6V systems. Make sure the starter is grounded to the frame. Remove and clean your cables. If someone has put skinny 12V cables on it remove them and get some 6V cables. You will probably have to go to a tractor store to get them.
Also do a search for "6V cables". | | |
#99885 03/15/2007 5:08 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Pull the plugs, run some ATF into each cylinder and crank the engine over for a few minutes with the plugs out; could be rusted cylinder walls. | | |
#99886 03/16/2007 1:00 AM | Joined: Mar 2007 Posts: 4 Junior Member | | Junior Member Joined: Mar 2007 Posts: 4 | OK, thanks guys, I will try that. I did put some Penetrating oil in cylinders, but maybe not enough. I will try both.
1951 Chevrolet 3600
#99887 03/17/2007 1:30 PM | Joined: Mar 2007 Posts: 4 Junior Member | | Junior Member Joined: Mar 2007 Posts: 4 | OK, I have discovered that my battery cables get really hot when I try to start it. I still will not turn over fast at all. Im thinking a starter problem. If so where do I get a rebuild kit for it?
1951 Chevrolet 3600
#99888 03/17/2007 4:49 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Warm cables mean high current. This could be the result of a tight engine, worn-out starter, or inadequate gauge battery cables. If the battery cables were changed (even 18 years ago), they are most likely 4 gauge 12v cables. You should have a minimum 2 gauge cable, and 0 or 00 (1/0 or 2/0) gauge is even better (both positive and ground cables). You will need these cables eventually, so replacing them is not a waste (about @$25). If the new cables get warm and/or the starter continues to be weak, then get a starter ($100-$150) Good luck - let us know what you do and what happens. Tim PS: Here is a fellow who sells starter and genenerator rebuild kits; he also rebuilds them: WEITZEL'S D.C. ELECTRIC 516 US Highway 250 South Norwalk, OH 44857 419-668-2844 866-840-2844 [email protected]If you send off your starter for a rebuild, use a Priority Mail flat-rate box. Costs about $8 to ship up to 70 lbs anywhere in continental USA. | | |
#99889 03/17/2007 4:51 PM | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | paws51!
I think Cletis has it right! Check those battery cables. They sound like they are probably for 12v system. Compare the cables at a 'tractor'/farm supply store and you'll most likely find that's where your problem is. Good luck. Let us know how you make out. Geo. | | |
#99890 03/18/2007 5:15 PM | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | I had the same problem I replaced the cables and had the starter rebuilt for good measure cranks real good now. Good investment should last for a while now... | | |
