New problem, I went and got a universal starter swich, hooked up the wires, turned the key to acc. and the starter began cranking. The switch has four posts, 3 of which are maked, the 3 that are marked are Batt. Acc. and ign. the fouth i believe would have to be the starter. I switched the starter and and ign. wires and still the same problem. Could it be the switch? or am I missing something? Thankyou.
