...as long as the tranny bolts up I'd check at the parts house and see what the engine calls for and go from there.
...yes, the driveshaft will be a "custom" made one.
I'm sure others with more experience will chime in. I put the 305 in my 1/2 ton panel but using automatic tranny..... .and yes, I used the flywheel the engine called for. Hope it works out.
