| | | Forums66 Topics128,204 Posts1,057,299 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | If you are referring to a 235 pistons are available for a .080" overbore so if it will clean up at that size the block is usable and will have nearly 250 cid. Sleeving is only cost effective when the block casting number is significant which really doesn't apply here....If it's a boat anchor find a donor instead. If it will clean up stick a 261 cam, fresh bearings and dual exhaust on it to exploit the additional displacement.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
