Originally Posted by Pre '68 Dave
What do you find wrong with drilling the two holes for the plate?
It is very simple and would cure your problems, and you have the plate.
Was not me that nixed it...it was my mechanic who found it flakey and likely to drill into a water line of some sort... I just follow his advice...
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
