Ah, Mike Reese (51 ashton) has tried to educate me on double clutching gear-shifting.
tim that was split shifting with a two speed rear not double clutching. even with the clark you will still need to split shift the rear
shifting with the clark will be simlpler since it has syncro's
its just like the one in your burb but with one more gear.
