Has anyone experimented with increased caster angles? From what little bit I've read its seems that steering is much more stable, but takes more energy to actually turn the wheel. I'm aware that the manual reccomends somewhere in the 2-3 degree range, but I'm curious if the added stability might be worth the extra effort.
