Bill,
If this rig has turn signals, which hasn't been revealed, and the wire comes out of the switch/turn harness as you indicate, how would a person achieve a left or right turn with only ONE wire to control both sides, as you also indicate. I'm not clear at all on this thought and I'll bet Roger isn't either.
Stoo!
