..... I work part time at Carolina Driveline and they use a lot of Spicer stuff that Ashton mentioned above. You should see the "array" of center bearings/seals they have and use. Pickups to Peterbilts!! If Spicer can't help you ask them who can. They're usually pretty good folks to work with.
