3 members (Gdads51, 2-Ton, 1 invisible),
103
2
Mod | | | Forums66 Topics128,137 Posts1,056,471 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I have installed the items you mention. Works well, normal labor required. My 15" wheels did work. Some may not, they caution you on that. I think I did a little grinding on calipers. "CPP says it MAY require a transmission mount" What is it? The booster does not need that and the discs don't need that? Are you saying you may need a different trans mount?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
