| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | It has a washer on the floor side the same diameter as the spring it basically floats on the shaft. You push the pedal in and it compresses, then when you release it pushes back out. It really does not hook to anything. Sometimes depending on the hole in the floor panel they will kind of twist in there and stick but they don't attach. | | |
