0 members (),
62
2
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | I've got a winter project. My 216 from 1941 had a problem with the compression on one cylinder - the other five read between 120 and 130. Number 5 was around 40. So I took off the head and found a broken oil ring but no visible damage to the cylinder. I am pretty green with this kind of work. The engine is in the car and I hope to leave it there. The car has under 80 000 miles on it, this is confirmed. I suspect that the more work I do on the engine the greater the risk that I screw something up. So first question - with everything opened up I suppose I would be wise to plastigage the mains and rods bearings and of course replace all the rings? Another question is why is the compression on 5 so low when the two compression rings are good? Yet another question is what rings to order. The engine has never been bored. There is a little edge at the top of the cylinders, so I will have to do a little honing- deglazing, but I hope to get by with as little work as possible, ha ha. Must I measure the cylinder to order rings? Is this a process with the pistons and feeler gauges? The engine has been running fine its whole life but leaves a lot of blue smoke. It was purchased new by my great-grandfather.
Karl It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | |
