Bill;
Ok. I just assumed that the front parking lights were also running lights. So they are working the way they are supposed to???
If they are functioning as designed, I won't worry about it. I may add the jumper to make them into running lights.
For the blinkers, I originally had the left front wires crossed. The parking light was bright and the blinker was dimmer. The other three blinker/park lights were matched. I cut the wires and hooked them up the other way. Now they match the passenger side and the rest of the lights. I also replaced the bulbs and put new wires in the sockets. The old wires were binding up and the spring wouldn't seat the bulb in the socket anymore. The light wouldn't work unless you pressed it into the socket. Anyway, I'll check the wiring one more time but I'm pretty sure I have it correct.
Thanks for the help.
Thanks
Larry
