| | | Forums66 Topics128,195 Posts1,057,369 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90938 02/13/2005 4:24 PM | Joined: Jul 2003 Posts: 141 Member | | Member Joined: Jul 2003 Posts: 141 | Originally posted by hrockwell: Is the sole purpose of the side terminal to send a full 12 volts to the ignition when the starter switch is pressed?
Yes. It also helps to prevent your alternator from running even after you turn off the ignition by forcing the circuit through a diode. | | |
